RCU Forums - View Single Post - Throttle linkage vibration
Old 12-18-2008 | 04:24 AM
selnekav
Default RE: Throttle linkage vibration
Hi
The problem is that i have no option to support the tube without bent it ( the direct line between the servo arm to the carb arm is about 2cm near the fuse side and 2cm below the fuse top side ) , that the reason that i used straight metal pushrod
