RCU Forums - View Single Post - Redesign and reconstruction of the Oldest Taurus on Earth
Old 12-18-2008 | 10:29 AM
  #146
kingaltair
Default RE: Redesign and reconstruction of the Oldest Taurus on Earth
ORIGINAL: kingaltair
Cees
If you want, why don't I take measurements of the canopy of the Taurus II, (which I believe you feel IS the original fuselage of the Wester Taurus).....that will give you an exact measurement.
On the other hand, from the other thread it was proven that the pilot figure in the crate picture, (PICTURE #2) is NOT the same pilot figure in the PRESENT Taurus II, (picture on the left). If you look carefully, you can see the difference in the way the pilot figures were painted. That means that canopy may not be the same one in the crate photo either, but there is no evidence to indicate the Taurus II canopy is not the original. The plane in the carrier picture is the same one I now have. It is the B&W picture on the left (where the plane is viewed from ground level from the side) above. That picture was taken during the very short span of time when Ed used the thick "carrier wing".
BTW-Cees. I just received a ST .56 for the plane, and it fits on the motor rails perfectly in the "slot" between the inside fuselage sides that frames the engine. It is as if the plane was made for, (or built around), a ST .56, but we know that's not true because the blind nuts fit a Veco .45. Ed designed two metal clips to hold the side engine lugs.
Duane
Duane, Ed did change the canopy after the period of the carrier and the thick wing that was my message, so it is what you write, I still think the centre section of the fuselage of Taurus II is from the Oldest taurus on Earth, but not the canopy. So I cannot use measurements of the canopy of Taurus II. That was why I did write: "For the canopy I will not use modern pictures anymore."
About the pilots.
The original pilot (your picture #2) of the crate Ed did remove with the canopy after the carrier period. This pilot did use space in the fuselage we can see on the crate picture.
The new pilot was later mounted "on" the fuselage in the new and much higher canopy.
About the engine.
The crate picture shows us the K & B Greenhead and the position about 8 mm higher in the fuselage. So that is the reason I use the adaptor plate now.
Ed did use an adjustable side thrust we can read so the ST wasn't original used for design of this fuselage. You cannot change the sidethrust of the ST....
Cees
[/quote]
Cees-The B&W picture of the "Carrier-winged" Taurus II shows the plane completed and ready for flight. We determined and proved for sure in the other thread that this was Ed's back-up plane for the 1963 "worlds", and it flew on proportional equipment. Due to windy conditions during the "worlds", Ed chose to fly his other Taurus, (the first one from the ebay auction that had reeds for radio).
The question I have is "why would Ed change canopies and pilot figures after the carrier wing periodthere isn't a reason for it"? Though you are obviously confident in your laser-beam measurements, I am not as confident in measurements made off small photographs, sometimes taken at undetermined angles such as the "crate photo". The angles may "play tricks" with the way things appear. The color photo you have marked at 45 degrees, I would have drawn at a lower angle. Drawing an angle on a continuously curving surface such as the front of a canopy is not precise, but is subjective, and may be influenced somewhat by what you are trying to prove.
I will admit that the canopy from my Dad's color picture seems to appear higher, but is the difference in appearance obvious enough to PROVE the canopies are different, or could it be just the photo or difference in camera angle? There is no trace when closely looking at the fuselage, that there had ever been another canopy on it in the past. There are also no cuts in the fuselage top block where a pilot may have entered the fuse in the past.
You may be right..just pointing out other possibilites.
Duane
