RCU Forums - View Single Post - Best Drift Chassis?
Old 12-18-2008 | 11:56 AM
xzavin
Default RE: Best Drift Chassis?
For 60 bucks more you can get a sick Yokomo, dunno that is what I would do!
You will find that the little money goes a long way with Yokomo, the base car is a bit pricey but its got a great setup.
Go to www.yokomo.com and select usa, go to car kits and scroll until you see the DP-DR1, then you will need tires, go to tires ->drift -> choose some pre-mounteds for your first set MAKE SURE THAT YOU GET TWO PACKS they come in packs of two....Next get a body Bodies -> get the body you want, I think the subaru looks beastly, next get some batteries, if you want to order a good set go to rcmart they have a good deal going on now with 2 4600s and a light kit for 86 dollars, great deal, then a charger, I will recomend one later, gotta go for now cya. Good luck.
