RCU Forums - View Single Post - Lanier 81" Cap 232 BUILD
Old 12-18-2008 | 03:17 PM
WarpedWing
Default RE: Lanier 81" Cap 232 BUILD
I'd recommend that you CG the Lanier CAP about 1/2" FORWARD of the wing tube for initial flights. The plans show the CG right in the middle of the tube-this is too far aft for most pilots (especially me!!!). Typically, this is hard to dothis plane tends to build tail heavy. You'll probably need to put the rudder servo under the canopy (pull/pull) and move your Rx battery all the way forward into the nose. Once you're used to the plane, you can move the CG aft in small increments. Use the "plan" throws for the elevator-you won't need much elevator throw for standard aerobatic flying. Have fun......WarpedWing.
