Hi all,
I am complete newbie, this is my first heli and I have nobody around to ask questions to
The assembly instructions are not quite clear (and I need your help here) about how exactly the upper fan collet should be placed above the fan hub: with reduced part toward the engine (hub) or vice versa?
I suspect that the upper collet should slide with it's reduced side into the hub and I tried to do that (by hand) but I failed - it seems that the coller is slightly wider then the hole in the hub.
Any comment are highly appreciated.
cheers,
slavik
