RCU Forums - View Single Post - Quick Learner assembly question
Old 07-23-2003 | 06:38 PM
tindra
Default Quick Learner assembly question
I can aswell admit that it was a stupid, stupid mistake of me. I had flown a few tanks and decided to play with the needles a bit. So I retracted the antennae in order to not step on it when the radio was on the ground. After some adjustments I stood up, grabbed the radio and started to fly again, without the antenna out! After 50 meters of flying the heli was almost uncontrolable. I managed the get the heli down to about 3 feet above the ground when it finally tilted to the side and the blades struck the ground. Damagereport: Bent main mast and tail axle, hillerarm missing(pobably in orbit!), bladeholder broken, flybar bent, servo gears broken in one servo and the rotorblades are about 200 mm shorter. Tailboom is ok! Could have been worse! I will never ever fly with a retracted antennae again! I will receive the spareparts tomorrow so it will soon be flying again!
Peter
