RCU Forums - View Single Post - Quick Learner assembly question
Old 08-07-2003 | 06:22 AM
slavik
Default I am little bit confused...
Originally posted by tindra
<snip>
Simply turn the head until there is enough room for the links everywhere. When done, the links will not be absolutely angular but a bit scewed. This is no problem when flying.
<snip>
Peter,
this was what I initially did but I was told that this is not right because the correct alignment of the rotorhead is when the flybar don't move on left/right cyclic command when it's aligned with the tail boom and on forward/backward command when it is perpendicular to the tail boom.
Is the above rule mandatory or not?
Unfortunately I have little time to surf the net for the answer.
Thanks in advance!
