Hobbico FlyZone Cessna 182 Skylane EP RTF
The Hobbico FlyZone [link=http://www.flyzoneplanes.com/airplanes/hcaa42-cessna182/index.html]Cessna 182 Skylane[/link] is an electric powered, radio controlled, ready to fly Cessna 182 Skylane scale model. Designed for beginning to intermediate flyers in mind, it is made from tough AeroCell foam and comes with everything you need to get started!
Features:[ul][*] AeroCell foam construction with pre-applied decals[*] Wings have functional flaps and ailerons[*] 5-channel Tactic 72MHz Radio with 3-position switch for flaps (Included - Requires 8-AA batteries)[*] Brushless motor power system (Included)[*] 3-cell 1800mAh LiPo battery pack (Included)[*] ElectriFly balancing charger (Included)[*] Blinking navigation lights[*] Pre-assembled Tricycle Landing Gear with front strut steerable nose gear[*] Canopy with plastic windows and detailed instrument panel in cockpit
[/ul]Specifications:[ul][*] Wingspan: 47.5" (1207mm)[*] Wing Area: 339 sq in (21.87) sq dm[*] Weight: 37oz (1049g)[*] Wing Loading: 15.72 oz/sq ft (48 g/sq dm)[*] Length: 39" (991mm)[/ul]
