RCU Forums - View Single Post - which conversion do I have?
Old 12-18-2008 | 11:28 PM
w8ye's Avatar
w8ye
My Feedback: (16)
Default RE: which conversion do I have?
The crystal goes in the receiver and that is what matters whether it is single or dual conversion
The RS 600 receiver is single conversion
RS600 6-Channel Universal FM Receiver w/o Crystal
Overview
Based on the popular R700 that topped the performance levels of all other FM receivers tested by a well-known independent lab, JR SPORT’s new 6-channel RS600 is a proven, shift-selectable receiver engineered to operate with all major transmitter brands, including Futaba and HiTec.
JR has a unique signal processing system called ABC&W. ABC&W stands for Automatic Blocking Circuit with Window. ABC&W systems have distinct advantages over single or dual conversion receivers. ABC&W systems create a very small electronic window that looks for the specific frequency that the receivers crystal is on. Any signal that is off spec for this window is rejected, and then the allowed signal is cleaned up, amplified, and re-routed through the window many, many times till all that is left is the pure signal on the channel that is coming from your transmitter and then sent on to the servos. This all takes place without any noticeable delay of response from your stick movement to the servo. This technology is the reason that JR can produce single conversion receivers that have fewer components and weigh less than other single and dual conversion receivers without the worry about outside interference.
Specs
* # of Channels:6
* Modulation:FM
* Band:72/75 Mhz
* Dimensions:0.61 x 1.84 x 0.98 in
* Weight:.64 oz
