RE: JetJoe OWNERS thread
What pump and ECU are you using ?
My settings are Auto+4 and 002,
You should not get that high of EGT, you must be getting a hot start, could be too much gas or not being turned off, it should be off at around 25K.
The fuel is turned on by the ECU registering 100°c from the thermo probe, is your probe calibrated correctly? it should be within a few diegrees of the actual temperature you are operating in.
