RE: Soldering Deans
I use a 60W iron, tin both the connector and the wire. I also put the connector together and then put a clamp on the opposite side of the connector to work as a heat sink to prevent the plastic from melting. I heat the connector tab until the solder melts and then lay the wire on top of it. I had problems melting the plastic until I started putting the connector together and using the heat sink. Good luck.
