RCU Forums - View Single Post - GP GEE BEE
Thread: GP GEE BEE
Old 12-19-2008 | 01:25 PM
  #542
foodstick's Avatar
foodstick
Default RE: GP GEE BEE
Nick you will be surprised how easy it takes off and flies, I would think as long as your planes wheels roll good and don't contact the wheel pants you should be ok, One thing I would check is this..if you slightly pinch the bottom of your wheels upwards into the wheel pant do they easily touch the inside of the wheel pant? If so they are going to touch when you land, at least for a second...now while they are pressed up in there take your other hand and see how much they are grabbing turn the wheel as if its rolling with some pressure on it..see how much grip it has, if it seems tacky, then try this mod, wrap black electrical tape around the outside of your tire like it is tread, now compress the wheel and try turning it again, it might help..it acts like a grease to keep it from immediately putting on the brakes at that critical landing moment...
I flew mine with my wheel pants WAY to long, and it wouldn't even roll in the grass, and since inexperience with the plane a a cross wind kept me off the landing strip I did the nose over, try to avoid the to low wheel pants, and sticky wheel issues! It will be worth the work, and slightly less showy wheel pants !
