RCU Forums - View Single Post - Starting SR. Tetemaster today
Old 12-19-2008 | 03:35 PM
vmsguy
Default RE: Starting SR. Tetemaster today
Good luck on your STM...
Mine is awaiting covering.
I found the fuselage to be a little to twisty for my taste. I could hold the fuse at each end, and twist, (like turrning a nut onto a bolt.)
I added diagonal bracing from the F3 back, which helped, but still not enough.
If I had to build again, I'd substitute in some stiffer wood for the center stringers on both the sides and top/bottom.
See:
http://www.rcuniverse.com/forum/m_82...tm.htm#8248351 (post 15)
