RE: 50 CC missing in midrange
I will check to see if it drops,, but from what I remember from flying yesterday it did not drop at full throttle at accleration. It stayed solid. I always allow a 30 second full throttle run prior to take off when the engine is cold.
When flying however it does pull stronger going vertical and runs smoother in a climb. Only level cruising at about 1/2 throttle does is seem to bark a bit.
