ORIGINAL: Old Fart
ORIGINAL: proptop
68" span Extra with a 2.20 ! WooHoo
![Big Grin](images/smilies/biggrin.gif)
What's the largest dia. prop you can get away with?
You might be able to make or buy a taller landing gear? There are manuf. that make specialty landing gear for Extra's, Edges, etc. and I think that's the way I would go...
![Smile](images/smilies/smile.gif)
would you believe the 220 is lighter than the recommended 26cc gas engine and makes more than an extra hp?
Prop clearance is just under an inch
O.F.... I believe it...the glow version of the 2.20/36cc Saito has gotta be lighter w/o all that ignition equipment, huh?
What size prop are you running or going to run on the 2.20?
