RE: pull pull systems kevlar or metal
Thanks for the tip Big Bird, looks like the solution the the problem I run into with my Ultimate. I am using a tuned pipe which a built a tunnel for, and I now cant get a straight run on the pull pull cables for the rudder. I will definately give that a try. Thank you
