ORIGINAL: jacjac
on giant scale gas, do u need to use kevlar for your pull pull system or is stainless ok? my concern is radio interferance
Hi Jac, If you are using 72 mhz. radio , then you must stay away form 39 inches of metal parallel to your rceiver antenna, it will cause glitches to you will be unable to fly the plane.
Jack
