RCU Forums - View Single Post - throttle linkage
Old 12-21-2008 | 06:21 AM
selnekav
Default throttle linkage
Hi,
I am using direct 2-56 metal pushrod between the servo and the engine carburator arm ( YS-110 ).
I can't use regular poshrod as i have no option to support the tube. ( the straight line between the servo arm to the engine arm is 2cm from the fuse side and also 2cm from the fuse top side )
the engine seat on hyde mount, and during operation the metal pushrod is shaking alot.... i am concern that it will
damage the servo ( and of course i guess it has affect on the engine rpm stability )
is there way to reduce the vibration affect on the throttle linkage ?
