RCU Forums - View Single Post - Help ? straighten Fuse sides?
Old 12-21-2008 | 08:18 AM
Popriv
Default Help ? straighten Fuse sides?
Tiger 60 kit.
I glued the fuse doublers around the wing area with titebond and when I dry fit everything the fuse sides both bow to the right....
While this may help with right turns its not what I want...
I sprayed lightly with water and wieghted it flat overnight but itstill bows right.
3-4 builds and I havent run into this before..
Is this a defect in the wood?
If they bowed in opposite directions they would cancel out.
How common is this? Will it pull together when glued up?
If I wet and bend in the opposite direction can I get the bend out?
Thanks for any help..
I'll move onto the wing for now..
Steve
ID:	1093753   Click image for larger version
ID:	1093754   Click image for larger version
