RCU Forums - View Single Post - Help ? straighten Fuse sides?
Old 12-21-2008 | 09:01 AM
TFF
Default RE: Help ? straighten Fuse sides?
Because it is a lock together structure, I would rubberband the forward together and see if it will lock straight. If you want to get picky most planes are crooked even if it is just a smidgen. I thought I got my last fuse perfectly straight, but no. You can lightly wet the one side that curves out and block an opposite curve in it and let it dry. Should be ok.
