Starter Plane...
I just started flying (did 1/8 and 1/12 scale cars way back) and picked up an Aerobird. I could not recommend it enough. It is very tough and very easy to fly. I don't understand why they push it as an "next step" plane, I did not have any trouble using the elevators to help with landing and quick take offs. I could not fly in my field with a 2 channel. If you are not confortable with the elevators then just don't use them. If you buy one you will probably want to get an x-pack as well. You will want the extra control you get with the bigger tail. I would also move the control lines to the holes nearest the tail right away, you get almost no control at all with the stock tail and the lines connected to the center hole. I have had mine for about a month now and have flown quite a bit with it. I take it to work with me and fly at lunch.
