RCU Forums - View Single Post - Help with Profili!
Old 12-21-2008 | 01:09 PM
Tall Paul
Default RE: Help with Profili!
You could plot each of your desired thicknesses in Profili, copy the results to a paint program, then combine the upper and lower profiles as needed...
For the first, plot an NACA 0005 and an NACA 0008.
Use the upper curve for the 0005 and the lower curve from the 0008 to get your desired shape.
And so forth.
Or, take the coordinates of each upper surface and lower surface and combine those into a new airfoil for Profili to plot for you.
ID:	1093861   Click image for larger version
