RCU Forums - View Single Post - throttle linkage
Old 12-21-2008 | 05:12 PM
Edwin
Default RE: throttle linkage
I like the lighter rod because is flexes easily when you move the throttle. On my saito's the throttle barrel moves in and out a little bit. With a stout rod, it puts a little tension on the linkage. As long as you're clear of any metal to metal contact the steel rod works ok, but only on a glow setup. I only use nyrod on my gassers.
Edwin
