ORIGINAL: tclaridge
Timer problem solved. OK now I just feel silly. My throttle hold is set to the mix switch. This makes a great engine on/off switch. Then I set the timer to the Mix switch. Problem solved! I was too caught up in trying to trigger the timer with the throttle.
Got my transmitter back. You are taking the long way around.....Turn the "One Time" to ON....it is OFF by default. That will solve your problem and get rid of the mix.
