RCU Forums - View Single Post - JetJoe OWNERS thread
Old 12-22-2008 | 07:17 AM
  #1883
bukeym
Default RE: JetJoe OWNERS thread
ORIGINAL: Xairflyer
Yes the ecu is limiting the revs as max is 800°c, dont change it max means max, best find out why your temps are high.
Is your temp probe reading normal room temp when turbine is cold ?
What tail cone do you have?
The temp probe reads normal room temp. No problem on that. The turbine balance is almost perfect. No abnormality with its revolutions on lower RPMs. The tail cone is the latest from Jetjoe ..somewhat smaller diameter thanlast year models. I will measure the inner diameter and post it tonight.. do I have to shorten it ? The thrust of the turbine is significantly lower at 137,000 RPM ... If I shorten the tail cone I will also lose thrust but I will probably reach 160,000 ...
