RCU Forums - View Single Post - Need some quick help
Old 12-22-2008 | 05:36 PM
pcsguy88's Avatar
pcsguy88
Default Need some quick help
Hey guys, I'm needing to place an order today for my Bradley conversion parts and need some help from those of you with all HL models. Yes Patton Commander, I'm looking at you!
I need treads that are under 1.25" wide. I know the PIII ones are 1" and should be perfect, but the sprocket is over 2" in diameter. Can anyone confirm this?
My Bradley's sprocket is 1.25" from tip to tip and there is not much more room for a larger sprocket. Maybe a 1.5" to 1.75" sprocket could be fitted without major mods and looking out of place.
Do any of you have suggestions on which HL parts will work? I only have a Bulldog and obviously those parts are way to large. I do not want to use VsTank parts because metal is a priority.
Thanks in advance for your help.
Ron
