ORIGINAL: LightC
Hey malice23,
I just pulled out my old red Fast Traxx.
It's time to give it some well-deserved upgrades
Aha, another Tyco fan. Malice should be able to tell you about the motors, he has one (the biggest, baddest one).
AFAIK, you should try and keep it as it is, i.e replace both motors (with huge ones) and both esc. This route should be easier than converting to brushless as i'm sure there is one motor for each track.
When i finally find the 'twister' this is the way i'm going to go, although the motors i'm planning on using might need to be mounted externally with some sort of crazy gearing
