RCU Forums - View Single Post - Modifying my Tower Trainer 40
Old 12-22-2008 | 08:31 PM
w8ye's Avatar
w8ye
My Feedback: (16)
Default RE: Modifying my Tower Trainer 40
On the tail wheel - I've done a few and I've seen all kinds of approaches to the steering problem
On mine in the picture I made a longer wire to go up and bend 90 degrees and epoxied into the rudder.
You have to have a bearing support up through the fuselage that aligns with the rudder hinge line
But your rudder hinge line is not perpendicular to the bottom of the fuselage???
I have seen one guy with a separate servo to run the tail wheel
After looking at the Tower Trainer, I would use the Dubro bracket.
Make a plywood shim to angle the bracket to where its pivot axis is the same as your rudder hinge line. Make a new wire for the bracket that goes up and is epoxied into the rudder
