RCU Forums - View Single Post - It might burn.............
Old 12-22-2008 | 11:43 PM
check6ii
My Feedback: (12)
Default RE: It might burn.............
ORIGINAL: KC36330
IF you ever use an off board propane setup just once you'll never use an onboard setup again...................but with that being said, with the minuscule amount of PowerMax in the onboard tank, if the Festo one way failed and it dumped it's contents into the fuselage it would be sucked into the intake, combusted and you'd never know it happened.
YEP!
