RCU Forums - View Single Post - JetJoe OWNERS thread
Old 12-23-2008 | 01:34 AM
  #1894
Shadow9926
Default RE: JetJoe OWNERS thread
Hi Myring
Idle is often when the EGT is highest, but your temps are too high. If you can notice any hot spots on the tail cone at idle , then I would suggest that you may have an uneven burn problem, either to do with the combustion chamber or a blocked fule manifold (more likely).
I have seen blocked fuel manifolds cause engines push the flame out of the exhaust and the needles on the JJ-1200 are only 24g so any small amount of dirt or flux from the soldering process could be blocking one or more needles.
Good luck.
