RCU Forums - View Single Post - FLy Eagle Jet Models
Old 12-23-2008 | 08:25 AM
  #1587
KC36330
Default RE: FLy Eagle Jet Models
ORIGINAL: Juan Garcia
.............................Also using flaps or flaperons helps. It reduces stalling speed. You will have more scale landings.
the only thing you need for a high AOA slow landings with a 16 is lots of back stick on final. an F-16 will fly high alpha at low speed all day without the necessity of flap/flaperon. Your broke gear sounds like you tried to float it in like a prop plane rather then pulling up the nose and using the turbine for rate of decent.
