RCU Forums - View Single Post - Xheli
Thread: Xheli
Old 12-23-2008 | 01:20 PM
  #103
DumbDawg's Avatar
DumbDawg
Default RE: Xheli
Fun... ROTFLMAO... Thats the K2 for yah... fly'n'fix cycle... doesn't end... Hopefully the EXI will lengthen the between cycle of fix'n and fly'n... I don't have to many parts for it... smeg I have way more parts for the K2 still in my parts bin than I have for the EXI... There are a couple trouble spots on the EXI that are cheap ixes... the flybar is soft as a noodle and the tailbox is troubles too... The tailbox I replaced after it failed with a metal box, grips and a belt for $20.00... cheap fixes for a smooth heli...
underdog... you can buy HiTec 65 servos for $20.00 a piece, a xmseller G401b gyro for $36.00 and the GL-WS2632 3500 brushless moto w/fan for $23.00.. assuming you have the Rx to go with ur 6i...
The Hitec may be the last servo's you have to buy because you can get gearsets for them and these are great servos... The gyro everyone is now talk'n about is the g401b which people are say'n holds better than the Telebee and its cheaper... Also the motor is great.. tons of power.. 350 watts of air chew'n grit... ar ar ar... Both the motor and gyro can be bought from cnchelicopter.com, the servo's can be picked up and Trex-Parts.com and I have another link if the rex parts one isn't on sale anymore... plus XHeli is having a super after christmas sale so some big deals can be got then too...
Hope this helps some... should get you fly'n well under $200... thats if you have the Rx and the Aussie dollar is low but still might get you there... happy holidaze
