RCU Forums - View Single Post - Is this possible?
Old 12-23-2008 | 06:12 PM
av8tor1977's Avatar
av8tor1977
Default RE: Is this possible?
Here is something similar to your idea Captain, and maybe a start? It doesn't create high tension voltage, but could run a battery powered ignition system without a battery. One would possibly have to buffer the circuit and use a voltage regulator if you wanted to run without a battery I imagine...
http://www.sullivanproducts.com/GenesysMainFrame.htm
AV8TOR
