RCU Forums - View Single Post - Sig Rascal 110
Thread: Sig Rascal 110
Old 06-22-2003 | 03:53 AM
wkndflier
Default Sig Rascal 110
I've got the 110, the wing is two pieces. I'm using the Fut 3004's on the ailerons and elevator w/ an Ht 625 MG on the pull-pull rudder. It's got the Saito 180 up front and this negates the need for the second half of the throttle control travel. I'm having more than my share of difficulty getting this thing to trim out and fly right. It flies like an overgrown trainer, and your life will be so much nicer if you can mix a little rudder on the aileron stick. This thing has proven that bigger isn't always better in the wind, it's so light compared to it size and doesn't offer much resistance to the odd thermal or wind gust. In an effort to get the saito dialed in and properly cooled I got lots of dead stick practice and I can tell you it has the glide path of huge wing glider, if you can see it you'll make it back.
