RCU Forums - View Single Post - gas reduction gear system
Old 12-23-2008 | 11:13 PM
  #32
mmattockx
Default RE: gas reduction gear system
ORIGINAL: hewismayer
I think regular bearings are fine the prop will pull 25 lbs tops if it’s balanced. There will be no up or down movement. If it’s a cog belt there will be very little tension puling down. They can’t be very tight or they will fail. Even bronze bushings will do. But you will have to grease on a regular basis. The shaft will only turn at 3000 rpm no faster then an electric motor. I think a lot less stress then the bearings in the engine that are under heat, and 3 times faster.
Sealed ball bearings should be fine, just check the axial load rating. The toothed belt will exert significant side force due to load and they do get tensioned a significant amount to keep them from jumping teeth. Just check the tension on a Harley belt drive and see how tight they keep those. It is still less tension than a V belt, though.
Mark
