RE: Hobbico FlyZone Cessna 182 Skylane EP RTF
After first installing eight AA-size batteries (not included) in the Tactic transmitter, you can center the aileron, elevator, and rudder trims. The throttle trim and throttle stick are both lowered all the way so the motor will not turn on.
You can then temporarily take the Tactic receiver part way out of the fuselage and hook up the controls. All the servo leads and navigation light leads are properly labeled. At this time, you can check all the control surfaces for proper swing and centering.
