RCU Forums - View Single Post - Attaching a Canopy
Old 03-21-2002 | 01:55 AM
JERRY RCIA
Default Attaching a Canopy
THE BEST WAY I'VE FOUND IS WITH LOW TEMP COVERING MATERIAL SUCH AS ULTRACOAT. CUT A STRIP ABOUT 3/8" WIDE AND POSITION 1/2 THE WIDTH ON THE CANOPY AND THE OTHER 1/2 ON THE PLANE AND SEAL WITH A COVERING IRON. THIS MAKES A VERY NEAT INSTALLATION AND IT'S EASY TO REMOVE THE CANOPY IF YOU SHOULD EVER NEED TO. I LEARNED THIS TRICK FROM A MASTER BUILDER AND HAVE NOT SINCE USED ANY OTHER METHOD. DON'T WORRY ABOUT MELTING THE CANOPY MATERIAL, JUST SET THE IRON AT LOW TEMPERATURE.
