You might know you are not alone dear Pratorian and that is the reason I'm asking.
FEJ too, sent me a pair of bigger cylinders for the mains, good friends from China. Any way I have to operate the system at 115 Psi. and in ocations is not enough but no doubt now is better.
Also the front gear doesn't lock. Here I studied the mechanism and noticed that shortening the air cylinder when colapsed or retracted solve the problem so I cut with a dremel tool the ball link a bit and now it works. Sometimes screw the ball link all the way into the cylinder shaft is enough.
The rest of the plane is good, like yours.
Thank's for your input, very appreciated.
And don't miss using your flaps.
