Problem with kevlar pull-pull setup - pls help
If what Don sells is the ACP setup (Kev-Cord) then these are NOT crimp fittings. There is a wide end and a narrow end. Feed the cord through the narrow end, out the wide end, around the eye-bolt/clevis/whatever and then back through the wide end and exit the narrow end. Tie a knot. It cannot pull back through the narrow end. Do NOT crimp.
Craig.
