RE: Kit: Glue technique
Mesa:
Now I am confused about the horn locations. Unless the control rods are too short, why not locate them in the stock location and just add 1/4" to the control rod length?
Also, should I use CA (per instructions) or epoxy for the fiber glass on control horn re-enforcement? For fiber glass, epoxy seems like the right thing to do.
I am not ready for pull-pull (in fact I am still not exactly sure how this works)...however, I really do think I will add 1" to the rudder...
I know TB is longer set times...this has to last me until April (post-thaw) so I am fine with taking months to do this. I can do a little each day/night..I am off for a week but then work will get very busy and having a bit of time here and there will suit TB well. My reasons for using TB is that I like the idea of having a LONG set-up time to get everything positioned just right. Whenever I have used CA, the 2-second ticking clocks makes things hard.
