RCU Forums - View Single Post - Problem with kevlar pull-pull setup - pls help
Old 06-07-2003 | 01:47 PM
CrashMeister
Default Problem with kevlar pull-pull setup - pls help
Through Bolt: Someone asked how the kevlar was attached:
You thread the kevlar through the center of the bolt and tie a knot. The knot is pulled tight against the end of the bolt (that's why you cannot see it). The knot cannot pull back through the bolt. Very secure.
Craig.
