RCU Forums - View Single Post - backordered, though at time of purchase.....
Old 12-25-2008 | 08:42 PM
opjose's Avatar
opjose
Default RE: backordered, though at time of purchase.....
Any good LiPo charger capable of handling 4S cells will do.
If you expect to stick with RC, a good computer controlled charger is a must.
e.g. Accucycle, Intellipeak, etc.
They are worth the expense as they will keep you from accidentally ruining your batteries and/or starting a fire!
Re: Fans
EDF Jet's need to be properly "broken in".
Make sure you follow standard EDF check out and break in proceedures, or you may damage the fans, motor and ESC.
