RCU Forums - View Single Post - Setting Engine Thrust
Old 12-26-2008 | 06:42 PM
jetmech05
Default RE: Setting Engine Thrust
most ARF's will have the offset built in...do you have a cross on the firewall...that will be the where the engine mounts both vertically and horzontally.....if the vertical line is not centered then the thrust angle is already built in
