RE: Triming and Setup- forward flight - T-Rex 450
Is there any interaction in your swash? with the motor disconnected, check to make sure that when you give forward elevator there is no right cyclic being applied. Then do it again while moving the throttle up and down. You might have a binding issue somewhere or you may have to play with the end points on your servos.
