RCU Forums - View Single Post - You will not believe this!!!!!
Old 12-26-2008 | 08:20 PM
ChuckW's Avatar
ChuckW
Default RE: You will not believe this!!!!!
To me, it sounds like the spektrum receiver went into fail safe for some reason. Problem is, it sounds like the fail safe position was full throttle rather than idle. Was it bound with the throttle sick forward or was the throttle maybe reversed after binding? That happened to me on an electric when I accidentally turned the transmitter off. If that's the case though, why did it lose signal and go into fail safe? Maybe the antenna being so close to the ground is an issue?
