RCU Forums - View Single Post - toe in
Thread: toe in
Old 12-26-2008 | 08:22 PM
Stick 40
Default RE: toe in
ITS ALIVE, ITS ALIVE again.
Hi thought this was dead, have not seen it for awhile.
The cubs are the only RC plane I have had a problem with, as fare as the ground handleing and this toe-in vs. toe-out. It had been years sence I put a .40 size cub together and I overlooked the toe-out of the wheels. I could not do a run for take off without ground loops and the landings were no better. I found myself applying full power and pulling it off the ground as quick as I could.
But after the input above and putting toe-in into the main gear, the plane turned into a great handleing plane on the ground. I even let it track with the tail in the air for 20 to 30 feet on landings without a problemI really started to enjoy flying it, and how others do it is of no matter to me.
Like RC KEN said the cub was the hard to handle on the ground, and I have to agree. But if set up right they are not that bad.
sticks
