Hello Ron,
Glad you received your engine. Dont worry for the space, we put a DA50 in our trainer 50 protoype and there is plenty of room all around. Your engine is almost identical to the DA50.
Only few more sleeps before you get the kit
By the way, i advise you that the kit you will receive was shipped before we add one piece that was added to the design after. It is the F19 plate. This can be replaced by a piece of balsa or if you prefer, Michel can send it to you. It is not a big part and it is used to close the fuselage at the rear of the wing before sheeting this area. I have added this to the design when the kit was already cutted and packed. The manual was aded in the box just before shipping and Michel was not aware of this addition. Or if you have some plywwod, i can send you a PDF drawing of the part and you cut it yourself (fastest method).
