RCU Forums - View Single Post - Help with Profili!
Old 12-27-2008 | 07:22 AM
fumus
Default RE: Help with Profili!
As you check the the site of rauch-airliner.com you could also see those profiles on model airplanes. The front view of the DC-8 model clearly shows the inverted profile at the wing root. It looks very scale-like and I don't think that the flight characteristics are so bad. Maybe fuel burn is a little bit higher as with a profile optimized for a model airplane...?
ID:	1097344   Click image for larger version
