ORIGINAL: kruser495
ever since i added the motor heat sink on my blade cx2 all it wants to do is vibrate. it is extremely uncontrolable and can not be trimmed. the swash plate is uneven and i dont know how to make is straight. could it have something to do with the servos? any ideas? thanks.
I cant see how adding the heat sinks would mess with the servos. Dit you get the moters
meshed with the gears good. You should be able to run a strip of computer paper through
the moter and drive gear to set the gear mesh.
Did the swash come apart ? To level the swash you hace to turn the linkage on the high
or low side to even it out.
