RE: JetJoe OWNERS thread
myring
The FADEC advice is still good for the Regal semi auto FADEC,
Pump start point, The values of “pump start point” from 0-8 in a auto mode, will adjust itself pump power to start it slowly. Settings
are either Auto or manual a value of 0-255. On manual the higher the number the poorer the pump or its running condition. So if fuel is slow getting to the engine go to a higher Auto say +4 to test it. I use manual to tell me changes in pump condition each year as a check.
Start Ramp the increase of fuel flow during the start phase. To greater value, more quickly the motor will accelerate until the idle (also note the hotter things get at the exhaust)
Test if your TX is correctly aligned, min throttle is may be 36k and max 160k.
Stability delay, the parameter allows to stabilize the power once this has arrived at the value set with the throttle control. The value must be increased if the power is not stable. normal set say 50 but you can use 100 if things are unstable with rpms up and down.
Change too many parameters and it defeats itself and so then return back to factory settings.
Paul
